GPU wierd power spikes
Go to solution Solved by podkall,
17 minutes ago, Threshis said:
so the spike up to 136 watts is completely normal for my model ?
most likely
image.png.323036fd5ace6dd49c5c30a210788b5b.pngimage.png.49d56a971ca671d33fbced9dbb52a6b6.png
So yesterday i noticed these wierd spikes in my RTX 4060 is this normal ? noticed GPU rail power / GPU core output power was pretty high 136 watts when my GPU only goes to 125w so i hope this is nothing wrong. i read about transcient spikes or something. hope you guys know more ❤️
https://linustechtips.com/topic/1581485-gpu-wierd-power-spikes/
current PC:
PC configs I used before:
https://linustechtips.com/topic/1581485-gpu-wierd-power-spikes/#findComment-16509641
13 minutes ago, Threshis said:
are the spikes im having normal and is it safe ?
yes, transient spikes are normal GPU behaviour
current PC:
https://linustechtips.com/topic/1581485-gpu-wierd-power-spikes/#findComment-16509663
most likely
current PC:
https://linustechtips.com/topic/1581485-gpu-wierd-power-spikes/#findComment-16509681
