pc build for ai programming/ computation heavy workload
Go to solution Solved by podkall,
13 minutes ago, ali.hmi said:
Arctic Liquid Freezer III 360 129€95
where? this one can start at 80€
https://fr.pcpartpicker.com/product/XgyH99/arctic-liquid-freezer-iii-563-cfm-liquid-cpu-cooler-acfre00136a
What about this?
PCPartPicker Part List
CPU: *AMD Ryzen 9 7950X 4.5 GHz 16-Core Processor  (€517.82 @ Amazon France)
CPU Cooler: *Thermalright Frozen Prism 70.4 CFM Liquid CPU Cooler  (€74.90 @ Amazon France)
Motherboard: *ASRock B650 PG LIGHTNING ATX AM5 Motherboard  (€161.49 @ TopAchat)
Memory: *Patriot Venom 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  (€199.99 @ Amazon France)
Storage: *Kingston KC3000 2.048 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€141.66 @ Amazon France)
Video Card: *PNY VERTO OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  (€818.10 @ Amazon France)
Case: MSI MPG GUNGNIR 110R ATX Mid Tower Case  (€88.99 @ Amazon France)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€104.00 @ Amazon France)
Total: €2106.95
Generated by PCPartPicker 2024-08-28 20:28 CEST+0200
Is specific GPU + specific CPU and decent rest the only requirement?
Budget (including currency): 2200€
Country: france
Games, programs or workloads that it will be used for: i don't know the specific programms that i will use but its gonna be for AI programming / data science projects, i would also like to play games i would like to be able to play AAA games on 1440p on medium settings on 60 fps
here is a build that i already found if you guys have any recomendations i would love to hear it,
MSI GeForce RTX 4070 SUPER VENTUS 2X OC   699€95
G.Skill Ripjaws S5 Black - 2 x 32 Go (64 Go) - DDR5 5200 MHz - CL40   209€95
Samsung 990 PRO- 1 To   139€95
Corsair RM750e - Gold (ATX 3.0) 139€95
MSI MPG Gungnir 110R - Noir 89€95
AMD Ryzen 9 7950X 619€95
MSI B650 GAMING PLUS WIFI 199€95
Do these require significant amount of CPU power or not really?
current PC:
PC configs I used before:
What about this?
Total: €2106.95
current PC:
at first i wanted to buy everything from the same store so that i could pay at month per month but when i see the price difference da****mn, i might just get a loan from the bank and buy everything where its cheapest. thanks for the recommendatios 👍
well, you don't necessarily have to get loan, if you have smaller budget, you could opt for slower parts and upgrade them later, for example CPU,
some of the things you mentioned might be GPU accelerated, not sure about data science, but AI is
current PC:
9 minutes ago, ali.hmi said:
thats true but i would like to be able to play games as well, and bank loans here are pretty good as a student i pay little interest rate which is pretty good
if that's the case and you're fine then it's okay,
for reference though you don't have to spend considerable amount of resources on parts you might not need,
you said you're doing AI and data science projects, is this something part of your school? if yes, then one more question would be, if they require you to have the fastest workstation PC money can ever buy, or if a midrange PC is enough, because if midrange PC is enough,
and if the school requirements isn't strict and 200% priority, you could get cheaper CPU, or in turn, better CPU for gaming,
but it does depend on what you need of course.
current PC:
yes it's for school and they actually dont require us to buy the pc i was gonna get a pc to be able to work at home since i live far from the university, but as you said i wont need the best parts i could just upgrade down the line, but i keep bouncing back up to the higher range,
i guess i could go for a more budget pc and upgrade it as needed.
i'll work on a more reasonable build do you have a good recommendation ? the more reasonable budget would be 1600 - 1800
If I were you, I'd strongly consider waiting until you start the course(s) before you buy anything, because often these projects are really simple and would run on a potato.
In terms of a lower budget option, a 4070 non-Super would be fine for 1440p/60 and even a Ryzen 7600 is pretty fast for most kinds of usage, though the 9000 CPUs could be worth considering too, due to the big uplift in some scenarios (you can check benchmarks on places like Phoronix and Puget).
yeah i'm getting a bit ahead of myself, i've been wanting to build a pc for a while just wanted to be perfect for everything 😞
i will wait and ask the researchers at the university, thank you guys for the insight, appreciate it 🙏
no probs, there's no shame in not getting the fastest parts, some people rock GTX 1050ti and are satisfied, it's just a matter of what you need, not really that much what you could have,
of course you can have headroom, but it doesn't have to be 3x headroom
current PC:
