macbook issue help!!!
Solved by Needfuldoer,
Is this your "pretty much brand new" one you got secondhand?
Who knows what kind of life it had before you got it. Check to see if the fans are clogged up with dust. It could've been sitting closed on a table connected to a monitor, mouse, and keyboard, never cycling the battery because it's always plugged in. (Cooling was never that great on the aluminum Intel Macbooks anyway; Apple prioritized low noise over cooling performance.)
The battery could be bad just from age, regardless of the number of cycles it has on it.
