Hi Guys! :D
I'm currently running this setup any suggestion in Overclocking, Future Upgrades, Software Optimizer, Anything that would really help in Optimizing the Performance and also can this Run Crysis 3 and Battlefield 4 in 1920 X 1080 in Ubber High Settings with no Issues.
Processor: Intel Core I5 - 4440
Motherboard: GA-B85M-HD3 Rev 1.0
Ram: G.Skill RipjawsX 8Gb 1600Mhz (F3-12800CL10S-8GBXL
Video Card: PowerColor HD7850 1Gb DDR5 256Bit (AX7850 1GBD5-DH)
Hard Drive: Seagate 1Tb 7200Rpm 3.5" Sata (ST1000DM003)
Power Supply: Thermaltake LitePower 600Watts Black Edition
Chassis: NZXT Source 210 Windowed White
Monitor: BenQ GL2250 21.5" LCD
Any Overclocking Tips Would Really Help. TIA/ \m/
CPU: Intel Core I5 - 444| Motherboard: GA-B85M-HD3 Rev 1.0 | RAM: G.Skill RipjawsX 8Gb 1600Mhz (F312800CL10S-8GBX) | GPU: PowerColor HD7850 1Gb DDR5 256Bit (AX7850 1GBD5-DH) | Case: NZXT Source 210 Windowed White | Storage: Seagate 1Tb 7200Rpm 3.5" Sata (ST1000DM003) | PSU: Thermaltake LitePower 600Watts Black Edition | Display: BenQ GW2255 21.5" LED | Cooling: Cooler Master Hyper 212X, Cooler Master Blade Master 120, Deep Cool XFAN 120 | Sound: Razer Kraken Pro, Marshall Major FX, Razer Hammerhead Pro, Audio-Technica ATH-M40X, Sennheiser HD 558, Antlion Audio ModMic 4.0, Fiio 6E Portable Amp, Creative Sound Blaster E1 Dac/Amp | Operating System: Windows 7 Ultimate 64 Bit
https://linustechtips.com/topic/158008-system-optimization/
You sure aren't going to be overclocking with that mobo and CPU.
https://linustechtips.com/topic/158008-system-optimization/#findComment-2106018
Your cpu is not overclockable.
Your video card is for med-high gaming but not ultra. There are not really anything else you can do.
You can try overclocking your gpu but it will probs give you 2-3 more fps.
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/158008-system-optimization/#findComment-2106025
Upgrades = Add an SSD and/or replace you graphics card.
Overclocking = NOT really an option without replacing you motherboard, cpu and HSF
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
https://linustechtips.com/topic/158008-system-optimization/#findComment-2106086
Any suggestions on Future Upgrades? i think the CPU would be ok as of the moment planning to have these first.
I'm planing to have these:
CPU Cooler: Antec Kühler H2O 920
GPU: GTX 760 JETSTREAM (2048MB GDDR5)
SSD: Samsung 840 Evo 120Gb
Case Fans: SilverStone FHP141 / SilverStone FM121 650
Ram: G.Skill RipjawsX 8Gb 1600Mhz (F3-12800CL10S-8GBXL)
any software (Freeware) suggestions? Benchmarks, System Monitoring, etc any suggestion would really help. :)
https://linustechtips.com/topic/158008-system-optimization/#findComment-2106109
