Budget (including currency):  200
Country: USA
Games, programs or workloads that it will be used for: Boneworks,alyx,fortnite,minecraft,rdr2
Other details I am currently looking at a Intel Core i5-12400 12400 4.40 GHz with 12 cores
is there anything for that price that is  better?
https://linustechtips.com/topic/1578146-i-need-help-with-a-cpu/
Do you already have the motherboard?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1578146-i-need-help-with-a-cpu/#findComment-16480988
22 minutes ago, Tetras said:
Best to avoid 13th-14th gen.
I hate that this is a thing now, but other than just losing performance, OP should go AMD. Also, we all are saying 12th gen is safe, but 12th gen also has failure rates, just no where near as much as 13/14th gen, who like actually have a problem now than just defective chips.
It all just clearly seems like a degrading issue. I mean seriously, 400 watts and 1.4+ volts through such small holes in some piece of silicon is truly physically aggressive. That is why lower TDP processors are not having this issue. Actually, a 13400 is not even listed in the ones have the problem, and is considered as safe as the 12400. We just need to undervolt and power limit these power hungry processors. Reducing max clock speed by a couple hundred MHz will help a lot, especially that the voltage will be lower. And proper cooling is also important too keep the voltages and power usage low.
What I would recommend for those with an already degraded chip and want to get it working, is to increase the voltages, and disable C states, but of course to not degrade it further, just limit the clock speed and undervolt if possible. If I really had one, I would even go scanning deeper and see if a particular core is degraded and causing the issues and then either just disable it or reduce its clock speed or just increase its voltage just a little bit.
PLEASE MARK COMMENTS AS SOLUTION IF SATISFIED!!
bigger number better, makes me look cooler.
https://linustechtips.com/topic/1578146-i-need-help-with-a-cpu/#findComment-16481001
Country: USA
PCPartPicker Part List
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($109.94 @ Newegg)
Motherboard: *ASRock B660M Pro RS Micro ATX LGA1700 Motherboard  ($94.99 @ Amazon)
Memory: *Silicon Power XPOWER Turbine 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($46.97 @ Amazon)
Video Card: *Gigabyte EAGLE Radeon RX 6600 8 GB Video Card  ($179.99 @ Newegg)
Total: $431.89
Generated by PCPartPicker 2024-07-31 16:58 EDT-0400
https://linustechtips.com/topic/1578146-i-need-help-with-a-cpu/#findComment-16481069
Country: USA
Not wise to separate budget amounts for individualsl components.
Why not post your total budget and we can work to build a nicely balanced machine?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1578146-i-need-help-with-a-cpu/#findComment-16481161
