Hey guys,
I am building a pc and I am trying to decide whether or not to go with air or water cooling.
I have heard alot of cool things about "be quiet", I have also heard for overclocking and for the best silence, water cooling is best.
I am trying to decide whether to go with a be quiet Dark Rock 3 or Corsair h100i.
https://linustechtips.com/topic/157705-air-or-water/
Generally the silence corresponds to custom loops rather than the prebuilt kits.
Both the ones you mention are good, just get the one that fits into your PC, budget, desired looks etc.. :)
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/157705-air-or-water/#findComment-2101742
so the dark rock 3 or corsair h100i, which one would you recommend for overclocking and best cooling
@squirrl
Depends on what kind of overclocking you want to do.
The h100i will be noisier, but you'll probably be better off with an NHD15.
Error: 410
https://linustechtips.com/topic/157705-air-or-water/#findComment-2101749
Water cooler is good but, later on you need to do maintenance, Finstack coolers just need proper cleaning alone , but usually it's maintanence free for most part, i'd reccommend you check out temp comparison on various other review sites before commiting to buy one!
Details separate people.
https://linustechtips.com/topic/157705-air-or-water/#findComment-2101776
isnt over clocking just one thing, making your computer run faster than it should
@helping
I think what helping is meaning is that how much of an OC you are after will determine your cooling. i.e. for a heavy OC you will likely need more than an air cooler or AIO water cooling and need a decent custom loop.
recommend any good ones?
@Tech_Dreamer
In terms of air coolers the NHD15 that helping suggested is pretty much the top dog and will give you pretty similar performance to any decent AIO.
Choosing between AIO watercooling and air cooling will largely come down to whether you have room for a radiator and aesthetics. Either way jump on anandtech, or techpowerup or any other decent review site and look at their reviews of different coolers for more piece of mind on what performs the best and what you can expect
https://linustechtips.com/topic/157705-air-or-water/#findComment-2101823
@helping
Yes, but it increases heat output and power consumption.
An air cooler will handle a mild overclock, an AIO, maybe ~200Mhz higher *under the assumption the chip can actually go higher* and watercooling gets the best of both in terms of acoustics and performance.
Error: 410
https://linustechtips.com/topic/157705-air-or-water/#findComment-2101939
Recommend any good ones?
https://linustechtips.com/topic/157705-air-or-water/#findComment-2102040
Fire nation ftw
Go air, it'll probably be cheaper, be less work, and perform about the same.
- "some salty pretzel bun fanboy" ~ @helping, 2014
- "Oh shit, watch out guys, we got a hopscotch bassass here..." ~ @vinyldash303
- "Yes the 8990 is more fater than the 4820K and as you can see this specific Video card comes with 6GB" ~ Alienware 2014
https://linustechtips.com/topic/157705-air-or-water/#findComment-2102043
recommend any good water coolers?
https://linustechtips.com/topic/157705-air-or-water/#findComment-2102045
Corsair h105
CPU: Intel core i7-4770 --- CPU Cooler: Corsair H105 --- GPU: Asus Geforce GTX 970 Strix --- MB: Asus Maximus VI Hero --- RAM: Corsair Vengeance Pro 16GB
Case: Corsair Obsidian 750D --- PSU: Corsair AX860i --- SSD: Seagate 120GB --- HDD: Seagate 2TB + Toshiba 1TB --- ODD: Asus External DVD-R
Keyboard: Razer Blackwidow 2013 Ultimate --- Mouse: Logitech G602 --- Mousepad: Corsair Vengeance MM600 --- Monitor: LG 29UM65
https://linustechtips.com/topic/157705-air-or-water/#findComment-2102050
@nosirrah123
recommend any good air coolers that will perform the same as water cooling
the case that I will be using corsair spec 02 atx mid tower, will a corsair h105 or any water cooler you recommend fit in this case
https://linustechtips.com/topic/157705-air-or-water/#findComment-2102074
Just had a quick look at the case on corsair's website. By the looks of things you could only get 1 120mm all in one water cooler (AIO) in there at the rear unless you remove the drive bays and mod the front a bit then you could maybe squeeze in a 240mm AIO but it does look it will require a bit of modding if it will work at all, sorry not familiar that particular case. So yeah without some custom mods of the case you will not bet able to use a h105 unfortunately.
If you already have the case or just really want that case I probably would just go with a air cooler like the noctua NHD15 as it will perform better than a 120mm AIO.
https://linustechtips.com/topic/157705-air-or-water/#findComment-2102263
Noctua NH14's are good a bit outdated tho since NH15's are out now & have pretty good design (you can fit the memory sticks with big ass heatsinks with this one , the older nh14's i think supported lower height version i think)
Reason for reccommending noctua is that it's dead quiet compared to some other finstack! (constant fan buzzing sound) Otherwise go for coolermaster evo 212's i think .. but noctua in the long run is better , So Final reccomendation from me is NH15's
BE WARNED!  (these are some of the bad sides of finstacks)
  • Assembling the finstack cooler is somewhat tough & confusing compared to water cooler installation & you can cut yourself if you hadle the stack improperly while assembling. (linus did it once i believe :P )
  • Make sure your case is big enough (width) , otherwise the side panel wont be able to close after fitting it.
  • you cannot modify the finstack in anyway , shave off the top edge or even wash it under high pressure water to clean it, the force can bend the stack lightly & hinder the airflow.
Check Out this indepth review from OC3D before making sure to buying one.. Do note that you may want to check those with higher efficiency, but we're talking a few degrees here . so NH15's are enough,
http://www.overclock3d.net/reviews/cases_cooling/noctua_nh-d15_review/1
:ph34r:
https://linustechtips.com/topic/157705-air-or-water/#findComment-2102303
@nosirrah123
I meant AIOs
https://linustechtips.com/topic/157705-air-or-water/#findComment-2102600
It honestly depends on how you'll be using your PC.
However, water cooling takes away the heat from your CPU to the radiator quicker versus air cooling.
You also need to know if you're going with Air Cooling, and your RAM slots are close to it, you need low profile RAM sticks as it might get in the way with your heatsink on the CPU as you're building.
Just go with water cooling.
Case: Thermaltake Core V71 CPU: AMD RYZEN 7 1700X (overclocked to 4.1Ghz) Cooling: Corsair H110i GT(Push-Pull config) Motherboard: Gigabyte's Aorus AX370 AM4 K7 RAM: G.SKILL 2800Mhz 32GB GPU:  GEFORCE GTX 1080 (SLI) from Gigabyte Storage: Kingston 3K 240GB (main boot drive) Crucial M500 SSD, WD 2TB Green, 100GB HD(As backup) PSU: Sseasonic X Series 850W Gold
https://linustechtips.com/topic/157705-air-or-water/#findComment-2102768
My friend recommended it to me since it is a gaming case. Please, you recommend a case that will fit a really good water cooler, don't hesitate to let me know
https://linustechtips.com/topic/157705-air-or-water/#findComment-2104379
Hey guys,
Air is fine as long as you don't mind the huge heatsinks: save up for a high quality silent one from Noctua
AIO: I recommend the NZXT X60 if you have room in your case and budget for a 280mm radioator
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/157705-air-or-water/#findComment-2104484
water cooling =/= AIO
water cooling is custom. AIO is lazy half assed cooler.
Great advice there from what appears to be a longstanding member....nice....good and constructive!
OP....either the 100i or the Swiftech H220 arebothverygood AIO Liquid solutions and both will provide slightly better performance cooling than any ir Cooler, more so if you replacwe the stock Fans that come with hem with btter quality Fans or have the room to set up a push / pull config.
The AIO will take up far less space on your Mobo so no concern using high profile RAM.
I started out with massive Air Coolers...then migrated to AIO Liquid Coolers before going to Custom Loop!!
There certainly is nothing "lazy or half assed" about using an AIO Cooler for your CPU, as a matter of fact I think its Overkill having an elaborate Custom Loop just to cool a CPU....
3930K - 4.85Ghz w EK Supremacy | RIVE w Photon 170 D5 Vario / Res Combo | 16GB 1866 Doms | Evga GTX 780Ti SC SLi w EK Full WB's| AX 1.2 kW | 900D - 1 x RX480 1 x EX360 & 1 x EX240 Rads w Noctua NF F & Corsair SP "Push" | W7 HP x64 | MK11: P25,113 http://www.3dmark.com/3dm11/7499603 | Firestrike: 19,576 http://www.3dmark.com/fs/1177627
https://linustechtips.com/topic/157705-air-or-water/#findComment-2105314
In the short time I've been fooling with true custom water cooling I've learned it's not cheap and really shines with high heat output. Moreover, a custom loop really is nice when cooling BOTH the cpu and gpu/gpus.  If you are only going to cool the cpu, even if OCing use a high end air cooler such as Noctua or a high end AIO such as Kraken  X60 or now Corsair H105.
I love tinkering with custom water cooling but it gets expensive real quick ( I love my MO RA3-420 but it's an example of expensive).
If you know someone local who has a custom water cooled system go over and talk to them and see it first before you dive into it.
5960x-4.4|AsusRE5|16g DDR4-2133|ZOTAC GTX 1080 FE-EK Block|2Smsng 850 EVO 500gb ssds Raid0|2Tb WD Blk|Win10-64|PC P&C 1200W|Thrmltake X9|Custom H20 cooling|Dell U3415W
4790k-4.7|AsusMxVIIH|16g DDR3-2400|EVGA GTX980TI SC-EK Block|Cru M500-240g ssd:500g WD Blk|Win10-64|PC P&C 950W|HAF932Adv|Custom H20 cooling|BenQ BL3200PT
https://linustechtips.com/topic/157705-air-or-water/#findComment-2105382
helping's opinions
-words in lieu of misplaced opposing opinion-
If you can't bear mine, please make use of the ignore function we have built into the IPB system.
Click on the top right drop down menu, then click on Manage Ignore Prefs. I'm sure you can figure out the rest from there.
At least learn to quote properly if you're going to call me out.
To OP if he bothers to read this thread anymore, an NHD15, PHTC14PE, NHD14, Dark rock Pro 3 will all serve you better for your usage IMO. If you need an explanation on that please tag me and ask.
Error: 410
https://linustechtips.com/topic/157705-air-or-water/#findComment-2105484
Yeah there is nothing wrong with it, it is just really not designed for water cooling whether it be an AIO unit or a custom loop due to the lack of radiator mounting options. Personally I really like the NZXT H440 but you would have to be happy with no 5.25" drive bays if you went with it and from what I read this seems to be quite a polarizing feature/or lack of.
If you want/need 5.25" bays then maybe look at a corsair 730T?
or you if you want to get really extreme a corsair 900d but that case would be a waste unless you were going with a full custom water cooling loop.
Cases are such a subjective thing though so you really need to just look for one that is aesthetically pleasing to you and has the features you want. Most case mfg's now state radiator support in their specs so just look for one that has at least support for a 240mm rad.
https://linustechtips.com/topic/157705-air-or-water/#findComment-2107355
