Vinyl cleaning
Unlike CDs, you want to clean LPs and 45s around their circumference, following the groove. I use a spray bottle full of distilled water (and spiked with a little isopropyl alcohol), then follow the grooves with a fuzzy paint edger (like this one), then mop up with a clean lint-free cloth. If you've got canned duster or an air compressor, blow as much dust off them as you can first, while they're still dry.
If you wipe them from the inside out, like you're supposed to with CDs, you can cause scratches that go perpendicular to the spiral groove.
Dust or scratches on an LP or 45 will just sound like a click. You may be surprised at how not-delicate they actually are. (Remember, back in ye olde days they were just how everybody bought their music, not precious collector's items.)
16 minutes ago, stefanmz said:I don't have a record player yet to test it.
When you get one please don't buy a Crosley, or any other modern novelty player that uses this plastic mechanism.
16 minutes ago, stefanmz said:Also if it's chipped on the side(during transport), like the edge of it is slightly chipped in one place is that a problem? It's not on the surface itself.
As long as the damage doesn't extend into the playable area, it should be fine. (And even if it does, you can just drop the tone arm further in than the damage extends and listen to the rest of the tracks.)
Can you post a picture?
