DPI and weight
Solved by podkall,
6 minutes ago, phil7990 said:I came across all sorts of DPI's and weights. What's up with that? Like does it benefit if you buy a mouse that goes to 25k dpi and you only play from 800-1000 dpi?
no
7 minutes ago, phil7990 said:And the weight, is it advicable to buyu a mouse that is heavier? I don't wanna fatigue my wrist, but somebody that I know said that I'll get used to the heavier weight. This true?
you can get used to heavier weight, ligher mouse can be preferred because if you in games flick often it's much easier to flick a ligher mouse,
also on low sens ligher mouse might feel better
as for DPI again, mostly marketing strat to advertise for high DPI,
all you really need is between 400-3200 DPI approx,
