Need help choosing processor
Solved by Tetras,
You're a lot more likely to get AM4 boards cheap, especially B450, but the 12100F with H610 or low-end B660/B760 is a budget choice and better than the 5500 for games. If you get a B450 board you lose PCI-E 4.0 anyway, so the Ryzen 5500 choice would matter less, though the 5600 is a significantly better CPU than both.
