Upgrading my power supply
Terryownzz
Hi,
I have been using a Corsair Cx 600 v3 power supply for 1.5 years and everytime i load a game, it coil whines. So i decided to upgrade. i was planning to get the corsair ax760 or the ax760i, but i couldn't find a place that had it in stock in Sydney Australia and i wanted it today because i work 6 days 10am to 10pm (im a chef). i uploaded pictures of before and after the upgrade. Im planning to buy the corsair blue individually sleeved cable kit. I know 860w is overkill for my system but i wanted a 80+ platinum power supply and be able to buy the individually blue sleeved cable kit and not have to buy extension cables. Also i plan to upgrade my gpu and get sli or crossfire in the future.
My computer specs:
cpu: intel core i7 2700k overclocked to 4.2 ghz using oc genie
motherboard: msi z77 mpower
ram: 4gb kingston 1333mhz value ram
graphics card: gigabyte gtx 570 soc
power supply Corsair ax 860
sound card: asus essence stx
storage: 120GB Kingston hyperX 3k SSD
cpu cooler: corsair h60
case: coolermaster haf xm with side window
lighting: 2x bitfenix 60cm blue led strips
fans: 3x coolermaster blue led 200mm fans and 3x coolermaster sickleflow 120mm blue led fans.
post-4764-0-80826100-1401102183_thumb.jp
post-4764-0-80530400-1401102215_thumb.jp
post-4764-0-76099400-1401102242_thumb.jp
post-4764-0-18217500-1401102267_thumb.jp
post-4764-0-45918900-1401102296_thumb.jp
post-4764-0-77867100-1401102326_thumb.jp
post-4764-0-85055400-1401102350_thumb.jp
post-4764-0-65581100-1401104038_thumb.jp
post-4764-0-64265000-1401104060_thumb.jp
MY PC SPECS AND SETUP: Intel Core i7 2700k @ 5GHZ, 8gb Kingston ram, MSI Z77 Mpower Motherboard, Asus Xonar STX, Asus GTX 580 Direct Cu2, CoolerMaster HAF XM case with side window,
Corsair H60, Noctua NF F12 Industrial PPC 3000 RPM Fan, 120gb Kingston Hyperx 3k SSD, Corsair Ax 860, 2x Bitfenix 60cm blue led strips, 3x Coolermaster 200mm Blue Led Fans,
Dell U3014 monitor, Das keyboard ultimate, Razer mamba mouse, Sennheiser HD 650 headphones, Corsair Blue Individually Sleeved Cables,  2x Logitech Z623 speakers,
Have I just been tricked into viewing a setup showcase? :lol:
You said upgraded not upgrading!?
Fixed.
You should consider getting a white led strip to light up you case, It brings out the beauty of build better than any color led could
Update:
I changed the 2 PCIE cables to the harness that has 2 6+2 pin connecters on 1 cable.
i changed the position of the harddrive cage so that i could use 1 sata cable to power my optical drive and my ssd.
post-4764-0-47181100-1401156449_thumb.jp
post-4764-0-67069200-1401156480_thumb.jp
