Samsung 990 Pro vs 980 Pro
The 990 Pro and 980 Pro are high end SSDs and with intensive usage you can feel the difference between them an lower tier SSDs. But the difference between each isn't that great. I used a 980 Pro in my last main system and have a 990 Pro in my latest gaming system. As such you can get the cheaper of the two.
10 minutes ago, Zech49 said:Mainly for putting games especially 4X/RTS.
Then there is this part. For a game drive you don't need the highest performance. A good mid range SSD will be a lot cheaper and do almost as well in practice.
5 minutes ago, Somerandomtechyboi said:also the 980 pro is outdated garbage dont bother with that thing, itll be slower than newer cheaper gen4 drives
It was a high end SSD in its day and it is no slouch today. Maybe it isn't the fastest in sequential, but it still has decent IOPS where lower tier SSDs can fall behind.
5 minutes ago, Somerandomtechyboi said:id avoid samsung due to how overpriced they are
I went 990 Pro for my latest build not because it was my 1st choice, but it was the cheapest available high end SSD at the time. Make sure you are comparing same performance class, sequential and IOPS. The mid range is great value but there is still a difference.
