6 foot tall case lol. Good idea, but how will you be constructing it?
If I may ask, why do you want 6 radiators? 2 480mm rads can be run with fan RPM's at ~600-800, which will make zero noise above ambient noises.
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2097170
I will and put one in the bottom bit.
thank you
Keep in mind, if you're putting those radiators in there so the system makes no noise, it won't work. You'll have to use your pump(s) at a higher RPM to produce adequate flow rates, in turn making the system louder from louder pumps.
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2097184
Maybe he could just have no fans lol
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2097207
4 pumps, 4 rads and 1 res?
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2097484
Where is the heat from the radiators going to go?
Why are there 2 pumps in series right next to each other?
Where are the components? Up top? Because the bottom radiators won't help in the slightest. The water will be cool by the time it reaches them.
That one bottom pump has to fight against gravity. Not sure if that will complicate things.
The case isn't 140mm deep. So exactly what are the dimensions of the radiators? And just how many fans will be included?
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2097537
The bottom pump shouldn't fight gravity that much, since i expect the water to flow downwards from the res into the bottom pump. I hope thats how the OP imagines it.
Main Rig
Phone
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2097547
yes
I think you'd be better off with something like a Phobya 1080 Rad
Should save you a lot of money too, since you don't need 4 pumps to fight gravity. One D5 should be enough.
Main Rig
Phone
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2097556
This will look great imo, where you will place this rig on the desk or ground ?
|EVGA 850 P2| |1440p PG279Q| |X570 Aorus Extreme| |Ryzen 9 3950x WC| |FE 2080Ti WC|TridentZ Neo 64GB| |Samsung 970 EVO M.2 1TB x3
 |Logitech G900|K70 Cherry MX Speed|  |Logitech Z906 |  |HD650|  |CaseLabs SMA8 (one of the last ones made)
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2097651
All i'm thinking is there better be something crazy going on inside this bookshelf to warrant that amount of rad space. if you just kept all your drives in one shelf (ssd, hdds, opticals and whatnot) then the mobo with the cooling loop in another, nice leds or somthing to show it off. then have the Phobya 1080 Rad (like @Butterfish had said) at the side or back or even the next shelf with some airflow going on through the sides, and the res. Having it so spread out will need more than necessary amount of fans, money and noise.
Corsair Graphite 230T Case , AMD A8 6600K 4-Core Processor cooled by a CoolerMaster Hyper 212X CPU Cooler, MSI A88X G45 Gaming Motherboard, Corsair Dominator Platinum 8GB 2133Mhz, Sapphire Radeon R9 280X Dual-X OC 3GB, Samsung 840 EVO Series 120GB SSD + Western Digital WD Green 1TB + 3x Toshiba 500GB HDD, Corsair CS750M Modular PSU,all cooled with 4 Case fans, Displayed in 1080p on a 50" Samsung LED Smart TV
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2097981
nitro portal, what rads, what pumps, what case?
I have a XSPC360(internal) connected to my MO RA3-420 (monster equivalent to 3-420 rads) and 1 D5 pump was enough but opted for a Twin D5 bay res to increase flow rate.
5960x-4.4|AsusRE5|16g DDR4-2133|ZOTAC GTX 1080 FE-EK Block|2Smsng 850 EVO 500gb ssds Raid0|2Tb WD Blk|Win10-64|PC P&C 1200W|Thrmltake X9|Custom H20 cooling|Dell U3415W
4790k-4.7|AsusMxVIIH|16g DDR3-2400|EVGA GTX980TI SC-EK Block|Cru M500-240g ssd:500g WD Blk|Win10-64|PC P&C 950W|HAF932Adv|Custom H20 cooling|BenQ BL3200PT
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2098106
Are you just thinking about this or will you be actually doing this? A one-off case of this size will be incredibly expensive and I am sure you will find out there will be plenty of materials challenges to make sure that case can withstand all that you want to put into it.
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2098158
What are you going to put in that thing? 4 complete system or a nuclear reactor?
The Mistress: Case: Corsair 760t   CPU:  Intel Core i7-4790K 4GHz(stock speed at the moment) - GPU: MSI 970 - MOBO: MSI Z97 Gaming 5 - RAM: Crucial Ballistic Sport 1600MHZ CL9 - PSU: Corsair AX760  - STORAGE: 128Gb Samsung EVO SSD/ 1TB WD Blue/Several older WD blacks.
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2099724
Have one of these in bottom
www.frozencpu.com/products/21234/ex-wat-269/Aquacomputer_Airplex_GIGANT_1680_External_Radiator_-_Copper_Fins_33302.html?tl=g30c95s667
Www.frozencpu.com/products/20515/ex-wat-257/Aquacomputer_Airplex_GIGANT_3360_External_Radiator_-_Aluminum_Fins_33303.html?tl=g30c95s667
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2101463
will this work?
Ok i have came up with a other case design
but what one will be better?
OR
Don't make multiple threads for the same build. Just edit your original post for further updates. I'm merging the threads.
https://linustechtips.com/topic/157344-extreme-case-pics/#findComment-2102452
