CPU or Motherboard Problem?
Go to solution Solved by OddOod,
1 hour ago, Superglitch said:
Reseated the CPU with heatsink removed to see if it warmed up at all and still had the same issue and CPU was cold to touch. Would that still be motherboard?
yes
Hi all,
Firstly here's the specs:
MSI MAG B650 Tomahawk
Ryzen 5 7600
32 GB DDR5 Corsair Vengeance 6000Mhz (2 X 16GB)
Verbatim 2TB M.2 2280 PCIe SSD
Radeon RX 7900 GRE
MSI MAG A750GL PSU
Recently splashed out and built a new gaming PC. However I've run into a catastrophic problem. After getting a successful post and installing windows last night, I did a quick restart to change some bios settings and the PC then failed to post and hasn't posted since. Everything turns on, fans spinning, GPU RGB etc.
Opening the case the motherboard has its EZ Debug light on for the CPU. once powered on even holding the PC power button down for any length of time won't turn off the PC. If I take the CPU out and power on, the same debug light remains on but if I press the PC power button the machine instantly powers down. I should also mention that mouse and keyboard wouldn't turn on either at this stage and are connected to motherboard USBs.
Basically I'm trying to ascertain if it's the motherboard or the CPU. Any help would be massively appreciated
Cheers!
https://linustechtips.com/topic/1572626-cpu-or-motherboard-problem/
That sounds like a motherboard issue. But would also check if it might be ram. If I would troubleshoot it, the first thing I would do is to reset CMOS and only try to one ram. If it still does not post, then I would reseat the CPU and in the process check for bent pins on the motherboard. I would even try to boot it while the heatsink is still removed, just to check if the CPU would even get warm or hot. If it does heat up, I would install the heatsink, making sure that it's only finger tighten. It The CPU isn't heating up and remains cold, despite the pc being on and there's no post. That's the time you either need an extra CPU and motherboard to check.
Throughout the years I've encounter weird issues that I still can't explain. Just like what happen to you, my pc won't boot. Did everything, the CPU does not heat up. Tried to reseat the cpu and checked the pins. Disassemble everything and put it back one by one and still nothing. Updated the  bios, still nothing. lol what fixed it was using another CPU from a friend. Didn't even change anything, after it boot successfully, I replaced and inserted my CPU and everything works like nothing happened.
4 hours ago, Superglitch said:
Hi all,
Ryzen 5 7600
Radeon RX 7900 GRE
MSI MAG A750GL PSU
Cheers!
If it worked then don't after fiddling in BIOS just reset the CMOS battery
4 hours ago, OddOod said:
If reseating the CPU doesn't fix it, you have a dead mobo. RMA
So I reseated the CPU and powered everything on without a heatsink to see if it got warm to the touch. Unfortunately it stayed cold. I don't have access to another AM5 board or CPU to test out 😞
yes
