PC will not display anything, DRAM LED is showing on Q-LEDs.
X570 Gaming-F
2x16 3600MHz DDR4 RAM
3070
I turned my pc off, came back another day, didn’t work.
I’ve tried a lot:
re-seated pretty much every piece of hardware in the computer
re-sat and replaced CMOS
tried one memory module in one slot for both and in different slots
checked all my pins
tried to flash a BIOS on a USB
checked all cabled
tried a different RAM stick and it flashed between DRAM and CPU LEDs once each time
Ran Out of things to do from here.
https://linustechtips.com/topic/1571825-pc-not-displaying-anything/
If it's tripping the DRAM or CPU LED and replacing the ram with an entirely different kit and testing each slot individually doesn't work. Plus the other troubleshooting you've done, then it's either your Motherboard or CPU that are bad. I'd find someone you know or a shop who can test it further if you don't have another Motherboard or CPU laying around to test in the system.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
I left it running and after 5 minutes it slowly POSTED through each LED. It went 1 LED, fail, 2 LED, fail, 3 LED, fail, pass, and then it booted and now it’s fine.
I have the exact same issue as you and have tried everything that you did (minus new RAM), left it on for 10 minutes and still, nothing.
My PC booted yesterday after leaving it for about 10 minutes. I’ve found out it’s not the DRAM LED being constantly on, and rather it’s my PC constantly trying to POST. It gets to DRAM, Fails, Tries again, and then sometimes it will eventually POST successfully. I have no idea what’s causing this.
