Just wondering if anyone else is having this problem...
Anytime I am doing a build list on the site, my browser (Firefox 29.0) keeps resetting the connection, and I have to keep reloading the page until it stops. I've been in contact with Ryan at PCpartpicker and he doesn't know what is going on. I've disabled add-ons like he told me and I'm still getting the problem.
This does the same on Chrome as well, with the exception that it just stops loading and doesn't inform me that the connection reset.
PCpartpicker is the only site that is doing this...no other site has this issue.
Anyone have any ideas?
Gaming/Editing PC: AMD FX-8350 | CM Seidon 120V Liquid Cooler | Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard | G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600| Gigabyte GeForce GTX 770 2GB WINDFORCE | PNY XLR8 240GB SSD | Seagate Barracuda 2TB HDD | Corsair 600W ATX Semi-Modular PSU | Thermaltake Chaser A71 | LG 25UM64-S 25.0" 2560 x 1080 Display | CM Storm Devastator Gaming Keyboard & Mouse
https://linustechtips.com/topic/156860-pcpartpicker-issues/
make a post on  pcpartpickers forums you will get more help there
Specs
https://linustechtips.com/topic/156860-pcpartpicker-issues/#findComment-2091232
Try out a free VPN/Tor and see if the problems still continue, could be that your ISP is unknowingly sending your traffic through a bad route.
https://linustechtips.com/topic/156860-pcpartpicker-issues/#findComment-2091271
Seems that since PCpartpickers was taken down for maintenance all day today. They seemed to have fixed the issues I was having, because I just tested it and had no problems (so far).
https://linustechtips.com/topic/156860-pcpartpicker-issues/#findComment-2121587
  • 1 year later...
