Is it worth it in 2024 to build a pc with R9 3950X?
Solved by filpo,
9 minutes ago, Mantas said:
Wow guys, thank you for such quick responses. Well my country is Lithuania, and I am not sure which GPU would be best, should I look for new or used, ideal budget for GPU would be up to 300 EUR.
A used 2080 ti should be around that price. Or a 6700 xt/6750 xt since that’s sometimes cheaper. Maybe even a used 3080 but check if that’s a scam. Used 3070 should be around that price but it’s only got 8gb or vram though that should be fine for 1080p
