Just wondering if everything is good so far and any advice on cable management is appreciated:http://imgur.com/LGhlRFG,BDMG8dM,1vyP0E3,Eo78Tar#2
Also i have a worry. Will it be trouble if the wire for the cpu fan(hyper 212) touchs my top exhaust: http://imgur.com/LGhlRFG,BDMG8dM,1vyP0E3,Eo78Tar#1
Lastly where do i connect these plugs:http://imgur.com/LGhlRFG,BDMG8dM,1vyP0E3,Eo78Tar#3<<<<<im using the nzxt 410 case.
My gpu, ram, and hdd hasnt arrived yet so i was wondering if i can power it on to see if the fans and everything work. This is my first build and  im really afraid that when i turn on the power, sparks start flying and everything just dies.
https://linustechtips.com/topic/156797-build-help/
1) try to rout everything you can behind the motherboard tray.
2) if it touches, it will make a loud rattling noise and you'll notice, it won't blow up the world though.
3) those look like from an integrated fan controller on your case. The Molex is for power, the 4 small connectors are for hooking up 3-pin fans
https://linustechtips.com/topic/156797-build-help/#findComment-2090226
I'm not very familiar with the 410 but they look like fan headers if i'm not wrong? down your case have a fan controller? Also make sure no cables are touching or near any fans that do not have a guard on them. Their should be cable holes where you can route some of your wiring through for a cleaner look.
My Little Gaming Rig:
CPU: FX 8320 | MOBO: Gigabyte 970A-D3P | RAM: G.Skill Ares 2x4GB | GPU: Sapphire Dual-X R9 270X | Storage: Seagate SSHD 1TB | Case: Corsair 200R | PSU: CM 550W V-Series
Upgrades to come: CPU FAN: Corsair H100i | RAM: 2 more 4GB sticks | GPU: Another R9 270X running in crossfire | Storage: Samsung 120GB SSD | PSU: Corsair 800w
https://linustechtips.com/topic/156797-build-help/#findComment-2090231
