Wolfenstein FPS Issues
Go to solution Solved by Hemanse,
Update: I've managed to resolve the problem with the latest GeForce drivers by checking the 'Include beta drivers' checkbox in GeForce Experience and downloading the 337.50 beta drivers. With them installed, the game runs much better and texture pop-in is less noticeable.
So i just bought Wolfenstein and sometimes the game just start laggin like hell, im maybe getting 3 fps. ASUS GPU Tweak says only 10 % of my gpu i being used and only 40 % of my cpu and thats on low grafiks :blink:
Im running Windows 7 64-Bit with an i5 and a GTX 660Ti.
https://linustechtips.com/topic/156768-wolfenstein-fps-issues/
reinstall or verify games cache, something might have gone awry during installation.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/156768-wolfenstein-fps-issues/#findComment-2089656
Ryzen 7 3700x, MSI B450 Tomahawk MAX, 16GB Ballistix Elite 3600MHz, MSI RTX 2070 Super Gaming X Trio, Corsair RM750x V2
https://linustechtips.com/topic/156768-wolfenstein-fps-issues/#findComment-2089661
Wat I5? could be a bottleneck
no
https://linustechtips.com/topic/156768-wolfenstein-fps-issues/#findComment-2089702
I installed the Beta driver and I got maybe 10 more fps, but still only 10% of the gpu was used.
How much VRAM is being used? I can't run the game without the texture compression enabled, enable that and drop some texture settings if you have to
- i7-2600k @ 4.7GHz - MSI 1070 8GB Gaming X - ASUS Maximus V Formula AC3 Edition - 16GB G.SKILL Ripjaws @ 1600Mhz - Corsair RM1000 - 1TB 7200RPM Seagate HDD + 2TB 7200 HDD + 2x240GB M500 RAID 0 - Corsair 750D - Samsung PX2370 & ASUS ROG SWIFT -
https://linustechtips.com/topic/156768-wolfenstein-fps-issues/#findComment-2089835
