I’m having an issue with my mom’s Delll Inspiron  5575 where I upgraded the storage by adding a new SSD and I tried to make that the primary boot device instead of the hard drive that it was originally running off of. it worked and somehow it stopped working and when I tried to boot from the SSD using windows boot manager in the bios, it kept boot cycling, so I took both the SSD and the hard drive out of my computer and put in my PC to try to see what the problem is, but I can’t access the SSD because it shows up in file explorer and management, but I can’t access drive the drive whenever I try, I met with a access denied message. I am lost and very upset. I have tried right, looking on the Drive and changing the permissions under the security tab, but I can’t figure out how to gain access access to the drive.
Have you tried turning it off and on again? Maybe Restart it?
Please make sure to Mark the Solution as a Solution.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ EVGA FTW Nvidia RTX 3090+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 16 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
https://linustechtips.com/topic/1567592-help/
Does the boot behavior in the Inspiron change when only the SSD is installed, and not the hard drive?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1567592-help/#findComment-16387613
no it only changes with both
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1567592-help/#findComment-16387642
right now it wont even boot it just keeps cycling
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1567592-help/#findComment-16387643
If you just have the hard drive installed, does the system boot, or did you already format the hard drive?
https://linustechtips.com/topic/1567592-help/#findComment-16387674
No, the system doesn’t boot with just the hard drive.
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1567592-help/#findComment-16387682
And the hard drive has been untouched? That is, you did not format it in any way - it is theoretically the same as it was before the upgrade to the SSD.
https://linustechtips.com/topic/1567592-help/#findComment-16387683
yes
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1567592-help/#findComment-16387773
1 minute ago, FI Fheonix said:
yes
I used a cloning software to clone the contents of the hard drive to the ssd becasue I wanted it to run windows off of the ssd instead of the hard drive becuase its extremely slow, im talking at least 2 minutes to get into windows. the hard drive isnt full of storage either, its a 1Tb and only 150gb of it are used.
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1567592-help/#findComment-16387775
16 minutes ago, FI Fheonix said:
yes
What happens if you try to put the hard drive into your PC? What shows up?
https://linustechtips.com/topic/1567592-help/#findComment-16387781
Everything. All windows files and personal files.
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1567592-help/#findComment-16387877
What kind of error do you get when trying to boot from the hard drive?
https://linustechtips.com/topic/1567592-help/#findComment-16387885
Just boot cycling, eventually windows tries to repair itself but it doesnt.
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1567592-help/#findComment-16391573
