how tedious and costly is the maintenance of liquid cpu cooler?
Solved by Kilrah,
1 hour ago, EzioWar said:is it possible that tube/liquid/pump would not be availabe anywhere when i would need to replace them?
AIOs are a sealed thing, not designed to be serviced. You won't find parts for it. Expect it to live 3-5 years and then replace.
Of course the fans are separate from the loop, you can replace them with whatever you want.
Featured Topics
Agall ·
Posted in CPUs, Motherboards, and Memory2 -
3
xKempo ·
Posted in Troubleshooting0 -
5
Dcorrigan97 ·
Posted in Troubleshooting1 -
Davidf4e ·
3
3
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
