Mouse keeps reconnecting and -eventually- disconnecting alltoghether.
Hi guys, im desperate for help here. Usually I can figure out everything by googling it, but so far nothing has worked...
Problem: My mouse randomly disconnects and reconnects within a second. There are days where this does not happen, and there are days where it happens multiple times. The mouse goes off for a second. The problem is not reproducible. I have found it happens more frequently when entering a Game of Transport Fever 2. But it also happens when I'm just browsing the Internet. Sometimes it just shuts off and does not come back.
I then have to physically unplug it and plug it back in for it to work again. Sometimes the Keyboard does the same.
Things I have done to solve the Problem that havent worked:
- Buy a new mouse. Happens with the new one as well.
- Try each and every USB port on the PC - no difference, even Front panel.
- Update the Mouse driver (They were up to date / its a generic driver)
- deactivate possibility for device to be "deactivated to save power" in device manager.
I somehow dont assume its a HW issue, as it happens with the other mouse and Keyboard as well as with different USB Ports (In case its a faulty port)
Specs:
Ryzen 5 7600
MSI B650 PRO Wifi
32GB DDR5 Corsair Vengeance 6000Mhz
RX 6800 XT 16GB
Samsung 970 EVO Plus M.2 NVME SSD
BeQuiet StraightPower 700w
Win 11 Home 64bit
BIOS 1.60 05.06.2023 (Updated at the Time of Build)
The PC was Built by myself back in 2023 - I am upgrading to a 7800X3D later this month (Also "Send back to manufacturer" would thus not be an option)
Hope you guys have some ideas because my knowledge has reached its limited.
Best,
Kriz
If you didnt tell all the things you tried, i would be like, this is a broken cable on the mouse.
But it happening with different mice, makes me think it might be power related.
Make sure all power connectors are fastened well.
Even go as far as unplug them and plug them back in. Specifically the motherboard 24pin.
If thats not it, it could be that the motherboard is faulty.
Best of luck, my lack of knowledge makes me unable to think of other solutions right now.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
