Need Help Designing Fractal Terra Build Based on Apr. 18 LTT Vid
18 hours ago, sophietlav said:other than the price
And that is why Terra is not my first pick even for smaller ITX build. Its price is well compensated with an amazingly built case, but its debilitatingly limiting to get more performance out of your thin budget. I would personally recommend to transition a well valued build into ITX later down the line instead of having to build it in a Terra now, or save up for a proper PC for your budget. Let me show you both plans.
Value+Transition Kit:
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor ($199.00 @ Amazon)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard ($119.99 @ Newegg)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($102.99 @ Amazon)
Storage: Mushkin Helix-L 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($58.99 @ Amazon)
Storage: Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($102.97 @ B&H)
Video Card: ASRock Challenger D Radeon RX 6600 8 GB Video Card ($199.99 @ Newegg)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case ($43.98 @ Newegg)
Power Supply: MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply ($59.00 @ MSI)
Total: $886.91
Generated by PCPartPicker 2024-04-19 19:52 EDT-0400
Motherboard: ASRock B650I Lightning Wifi Mini ITX AM5 Motherboard ($199.99 @ Newegg)
Case: Fractal Design Terra Mini ITX Desktop Case ($179.99 @ B&H)
Power Supply: SeaSonic FOCUS SGX (2021) 750 W 80+ Gold Certified Fully Modular SFX Power Supply ($109.99 @ Amazon)
Total: $489.97
Terra Build on your criteria:
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor ($183.00 @ Amazon)
Motherboard: ASRock Z690M-ITX/ax Mini ITX LGA1700 Motherboard ($134.99 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($54.97 @ Amazon)
Total: $824.90
Generated by PCPartPicker 2024-04-19 18:37 EDT-0400
Add GPU later down the line, and install the Linux on a separate 1TB drive. A lot of people have issue with partitioning specifically for Linux where Windows deletes parts of the Linux partition, leaving the install brick.
18 hours ago, sophietlav said:I have a couple 1tb hard drives scattered around
PS: this case only supports 2.5 inch drives, so if its the bigger 3.5 inch, you are SOL. Either you have to put it outside of the case, or get an external HDD encloser.
