Thermaltake Core P8 Riser Cable
Go to solution Solved by downinthemorgue,
Unfortunately, the riser that came with the case was PCIE2, Guess I have to buy a new one. Thanks to everyone who replied, Have a great Day!
So I bought a thermaltake core p8 case and I was wondering if anyone knows if the riser cable that comes with it is compatible with a rx 7900xtx or if I should buy a new one? If so any recommendations for a riser that fits in the thermaltake core p8? Thanks!
https://linustechtips.com/topic/1566755-thermaltake-core-p8-riser-cable/
Not my personal experience with GPU risers from Tt and others, but I was recommended to get Linkup GPU riser for my RX 7900 XTX, which I'd gotten some 15 months back. I was told using generic or other brands, especially generic ones, will result in BSOD, WHEA errors and such, so I'd had to pick the expensive alternative below.
It's been about 15 months now since I'd gotten it for my main rig, and it's working perfectly fine, no issue with games and benchmarks. Instead of going through the trouble of having issues with generic or meh GPU risers, not to mention the time and effort (and money) spent on risers that do not work, might as well bite the bullet and get a good quality, albeit expensive riser.
Still, that riser that cable that came with your case might just work, I dunno for sure, give it a try and see what happens.....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
Can't see any specs on the riser cable, but why wouldn't it work? Might only be PCI-e 3.0, but that wouldn't make much difference with 7900XTX anyway
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
It should work, you might initially get a display when you power on, but best way to check is to run HWInfo, GPUZ to check if the GPU is running as spec'ed.....that is, IF the mobo is PCIe 3.0x16/PCIe 4.0x16, that the card is running at that spec, and not PCIe 1.0/1.1 or whatever the case may be. When I was looking for a GPU riser, I'd read that the Linkup riser I'd gotten was the only one guaranteed to work at PCIe4.0 x16, and it did, still does. Again, nothing wrong with trying out the GPU riser cable that came with the case.....tech might have improved since last year when I got mine that just about any riser works perfectly, who knows?!
I'll certainly give it a shot, hopefully even if it's pcie 3 my frames don't dip too hard. Thx for the advice!!
That would be surprising...  PCIE Gen 2 went out of style with 4th/5th gen cpu's?
