Im going to build a pc, but is a pure rock 2 cpu cooler enough for a 7700x?
Go to solution Solved by aren332,
4 minutes ago, awdasdwasdfgeasdf said:
the phantom assassin and peerless assassin are like 50 euro and i cant afford that in my budget, so i'm looking at the pure rock 2.Would that work or would the cooler not be strong enough
yeah it should be fine
