Cooler master case from the 2000s Era need help identify
Solved by aisle9,
Centurion. I don't remember the exact model number and I know they made a ton, but that's definitely a Centurion.
What parts are you looking to buy for it? I ask because on a case that age, it might actually be cheaper to buy an entire system in a Centurion case off of Facebook or Craigslist or whatever, salvage what you need from the case, then resell it. Buying individual parts for cases that old off of eBay gets absurdly expensive really quick.
*Edit: or buy generic parts, if it's 5.25" bay covers or something that you're looking for.
