Arch gets less FPS (200FPS difference) on my machine then Ubuntu. What can I do?
With the help of the wonderful people on the Arch Forums we diagnosed the problem as a CPU governors issue.
I quickly went to run this command which changed the governor from power saving to performance (according to the wiki)
cpupower frequency-set -g performance
Here is how you set it permanently.
Apparently the power saving mode actually makes the CPU run at a lower frequency, which explains the high CPU usage, as CPU status reporting programs usually scale their output to CPU frequency, not full load (which makes sense because there are people who overclock or underclock their CPUs). Thus the performance has been improved by more than 5x, I calculated that roughly from the results I had seen before and compared them to the ones I have now. (including less CPU usage)
I jumped into the game and the CPU usage was way lower, in some cases it was identifying as 0% while doing less intensive things. Beforehand it was around 10% (remember this is a 36 thread CPU). The game is now running better than it does on Ubuntu, just like I first expected.
