Repairing Micro USB port on keyboard by Soldering cable directly to pads
micro-B header always (there might be some exception) have the same sequence. So you only need to figure out if they are left to right or right to left (which also correlate to which orientation the micro b plugs in).
On the right there is this yellow blob. A tantalum capacitor. Dark red line is the (+) side. Very likely this pin is Vcc so mystery already solved but let's continue to double check:
Right next to it is U6. this is a ESD protection diode and the traces look like differential impedance controlled transmission lines. No clue what D+ and D- are. But we know that this connector has likely the normal pinout so we can make an educated guess that the right is D- and the left is D+.
Next in line is the pin connected to a large copper area. Sounds to me like it could be ground.
The remining pin on the left is tricky. By the pinout we know this should be the ID pin but why is there R3 and C5? Can't read the values but once more an educated guess would be a pF-capacitor and a high value/impedance resistor. This is likely for EMI reasons.
