I am thinking about moving to KDE & I want all my settings for my apps. I wish I could just put in on what I have now, but I have Mate. That is not a good 1. I was just thomking I could just copy .mozilli & the app folders I wan't from .config, but Caja alwys freezes when when I copy big floders.
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/1566448-copy-home-with-rsync/
Just install KDE desktop environment from your package manger? When logging in select kde as the environment.
If you want to backup home folder use timeshift.
https://linustechtips.com/topic/1566448-copy-home-with-rsync/#findComment-16379358
12 hours ago, goatedpenguin said:
Just uninstall Mate and install KDE simple. You won't lose all your apps and data etc. Its just a DE at the end of the day.
I was thinking that,so I did this before, but I do not see where to boot up to KDE, nothing on SDDM? Plus, if I get rid of mTE fter it will get rid of the network manager, etc for mate right? Any this is how my distroes site instructions. https://wiki.manjaro.org/index.php/Install_Desktop_Environments
https://linustechtips.com/topic/1566448-copy-home-with-rsync/#findComment-16380302
28 minutes ago, goatedpenguin said:
Can you send a screenshot of what will be uninstalled from the command line? Btw there is no need to use the -Rns flags just simply use the -Runs flag. The second flags given are more preferable and safe than doing -Rcns
?? OMG, think that font could be a little better, but ya KDE is not on sys when I click nothing happens.
https://linustechtips.com/topic/1566448-copy-home-with-rsync/#findComment-16380313
When you’re removing mate send the screenshot of what packages are being removed.
I'm thinking, why remove mate at all, just leave it in the background, well for at least 6 months or so until you are "happy" with your new DE.
https://linustechtips.com/topic/1566448-copy-home-with-rsync/#findComment-16380360
How do I make the mouse pointer bigger?
https://linustechtips.com/topic/1566448-copy-home-with-rsync/#findComment-16380364
The mouse pointer is tiny, I need to change that so I can see it. I decided to stay with Mate.
https://linustechtips.com/topic/1566448-copy-home-with-rsync/#findComment-16380376
there should be a config in System Settings for that.
If you search for cursor on the Kickoff (application menu) or KRunner, it'll be there
Also, when I use rsync I do
rsync -avP /home/<username> <destination>
the parameters are:
  • a - archive
  • v - verbose
  • P - --partial --progress
Desktop
Y4M1-II: AMD Ryzen 9-5900X | Asrock RX 6900XT Phantom Gaming D | Gigabyte RTX 4060 low profile | 64GB G.Skill Ripjaws V | 4TB Samsung 990 Pro + 8TB WD Black SN850X + 4TB 870 EVO + + 8TB WD Black HDD | Lian Li O11 Dynamic XL-X | Antec ST1000 1000W 80+ Titanium | MSI Optix MAG342CQR | LG DualUp | Tuxedo OS (Plasma)
Mobile devices
Kuroneko: Lenovo ThinkPad X1 Yoga 4th - Intel i7-10510U | 16GB RAM | 1TB SSD | Pop!_OS (COSMIC)
Norena: HP Pavillion 15 with Ryzen 5 & GTX 1650
Black Decker: Steam Deck 512GB model; swapped storage 2TB NVME
Sylver: Galaxy Z Flip 6
https://linustechtips.com/topic/1566448-copy-home-with-rsync/#findComment-16382472
Well I think my MB is starting to die, USB liveboot for Manjaro KDE will not bring up the DE, same with Opt drive. A blue/green (a bit color blind) comes up like the DE is about to come up, just stays blank, Mate doesn't boot into DE also, a oddness with a graphic in the screen color. On a oldeer sys they all boot fine, the DE loasd up & all is good. I even took the drive with Linux already on it out, installed Manjaro KDE on anther sys then put it back onto this sys, same thing. So the drive isn't bad, the DVD or USB isn't either. The drive
https://linustechtips.com/topic/1566448-copy-home-with-rsync/#findComment-16383928
