Help in cloning os...
Go to solution Solved by Dedayog,
Just now, goldPHANTOMyt said:
The HDD has max capacity of 1tb but it has files which add ub to around 700gb, is there any way i can just move my os so that the os will run off the ssd and i will keep my personal files in the hard drive? And the ssd is not from samsung or crucial.
Or is there anyway that i can just reinstall windows and choose the ssd for the installation but not remove my files from the hdd?
I am new to this so I am really confused as of now
Yes,, reinstall Windows and you can select the SSD from the install menu...  When you see this, it will list your drives and partitions.  Pick the 500GB SSD.
Then make sure to go into BIOS and select the SSD as the new boot drive, since both have Windows on them.
How to Install Windows 10 on a New Hard Drive (with Pictures) - MiniTool  Partition Wizard
So I recently got a ssd, and installed it in my laptop, the ssd is 512gb and i have a hdd which has my os and all of my files 1tb in size, what I wan't to do is shift my os from my hdd to my ssd, could anyone suggest a way or a method to do so? I hope it doesn't include any paid software
https://linustechtips.com/topic/1566439-help-in-cloning-os/
Get Macrium Reflect.  Clone the HDD to the SSD, provided the entire size of the data will fit on the SSD.
Is the HDD a 1TB HDD, or are all your files adding up to 1TB?
If the SSD is a name brand like Samsung or Crucial, they have their own software for free as well.
Note:  You can't just easily move the OS alone, so I am advising to move ALL stuff off the HDD and lose the HDD.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1566439-help-in-cloning-os/#findComment-16379252
Just makesure the files inside of the 1gb hdd are not upto 500gig if not it would create some issues which is self explanatory.
https://linustechtips.com/topic/1566439-help-in-cloning-os/#findComment-16379257
https://linustechtips.com/topic/1566439-help-in-cloning-os/#findComment-16379265
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1566439-help-in-cloning-os/#findComment-16379266
And then can I delete the windows files from the hard drive?
Do i do this from window's backup and recovery section, as I said I am really new to this could you link a guide or a explanation as to which way I should reinstall windows?
Edited by goldPHANTOMyt
Had to ask another question
https://linustechtips.com/topic/1566439-help-in-cloning-os/#findComment-16379267
Always install Windows fully, never restore.
https://www.microsoft.com/en-us/software-download/windows10
These vids can walk you thru...
https://www.youtube.com/results?search_query=how+to+install+windows+10+from+usb
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1566439-help-in-cloning-os/#findComment-16379270
THANKS!
https://linustechtips.com/topic/1566439-help-in-cloning-os/#findComment-16379273
THANKS!
Oh and don't worry about needing a license or buying one.  You can run Windows unactivated without issue.  I do on multiple machines.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1566439-help-in-cloning-os/#findComment-16379274
Welcome to the forums!
Absolutely. when you install it will show the available drives and you just select that one.
You can often even harvest the activation key from the old install.
https://linustechtips.com/topic/1566439-help-in-cloning-os/#findComment-16379349
