First Build (Input on parts would be great!)
1 hour ago, Dripzy said:I’m confused by what you mean. I will include the URL, however your reasoning doesn’t make sense as I am using a Phone to post this and can expand the photo just fine.
Thanks. I'm using a tablet and having to enlarge and shrink stuff is a pain. Plus the link allows one to drill down into part details and play around with options.
Consider a better CPU cooler. Modern CPU tend to improve performance as much as the cooling allows.
You can save a few $ on the memory kit. The one in my list includes both EXPO and XMP profiles.
I suggest a PSU that is ATX 3.0 compliant and supports the 12VHPWR connector used by the GPU.
If you have a bit more to spend, consider a case with front panel USB-C.
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor ($206.99 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($33.90 @ Amazon)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard ($119.99 @ Amazon)
Memory: Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($97.98 @ Amazon)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($69.99 @ Adorama)
Video Card: Zotac Twin Edge GeForce RTX 4070 SUPER 12 GB Video Card ($589.99 @ Amazon)
Case: Deepcool CH370 MicroATX Mid Tower Case ($59.99 @ Amazon)
Power Supply: ADATA XPG Core Reactor II 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($87.99 @ Amazon)
Total: $1266.82
Generated by PCPartPicker 2024-04-10 19:53 EDT-0400
