Need new cable for 4k 240hz monitor need advice
missing1981
Hi. I am from the UK.
I have just ordered a MPG 321URX QD-OLED
https://www.msi.com/Monitor/MPG-321URX-QD-OLED
And I need a display port cable. That is 5 metres long. And can broadcast 4K at 240 Hertz
Do you have any suggestions as there are so many out there
Thanks
The monitor should come with one.
Or you need exactly 0.5m ?
Also - nice choice of monitor.
I edit my posts more often than not
I assume the period is a typo and they are saying 5m long.  In which case, I'd get an optical cable.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
6 minutes ago, Tan3l6 said:
Then one like this should do?
Amazon
Like I said, I'd get optical as copper cables of that length can be sketchy and more importantly tend be quite thick and heavy.
I've had the monitor port start to fail due to thick cables before.  I've also not had a single random drop-out since switching to optical, used to happen with copper.
For a new monitor why is it
dp 1.4a not 2.1
1 x DisplayPort 1.4a
2 x HDMI™ 2.1 (4K@240Hz)
1 x Type-c (DP alt.) w/PD 90W
dp 1.4a not 2.1
First, because DP 1.4 has more than enough bandwidth to support the resolution and refresh rate when using DSC, which is a visually lossless compression format.
Second, because except for the very latest generation of AMD GPUs, all GPUs on the market only have DP 1.4 ports.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
