PC freezing on start up
On 4/8/2024 at 8:00 PM, Vicarian said:QVL for your motherboard:
https://dlcdnets.asus.com/pub/ASUS/mb/SocketAM4/ROG_CROSSHAIR-VIII-HERO_WI-FI/Memory_QVL_for_AMD_Ryzen_5000_X570-4DIMM.pdf?model=ROG CROSSHAIR VIII FORMULA
I assume you have 4x32. If your memory is not in that list in a 4x32 configuration (note the pips in the last 3 columns), try going to 2x32 in dual channel (refer to your motherboard's manual) and see if things improve. Shoving 4 memory modules into motherboards does cause stability issues in certain situations.
If reducing memory modules doesn't work, if you have a friend with a known working spare GPU, or have an old one laying around, run DDU (Display Driver Uninstaller from Guru3D), then shut down and swap cards. You might try even running DDU and redownloading the driver for your current GPU to do a completely clean install.
If that doesn't work, try reinstalling Windows. You'll likely need a spare machine to create bootable media if you can no longer get into Windows on this one. Guide and download by Microsoft here.
Turned out to be a faulty CPU
Replaced it and all is working now
