Using an molex adapter for a GPU ?
Solved by TatamiMatt,
Im not entirely sure on this as i havent ever needed to resolve a situation quite like yours, and would recommend taking advice from someone more experienced than me, but imo, it sounds pretty fine, 2060 is a 160W card and 75Ws come from the PCIe slot, so youre pulling 85W through molex power or about 42.5W through each molex cable, which honestly isnt a whole lot, about 1/3ish of what molex's max wattage is (if im correct with that number), and this is only at full power, the gpu wont always be at full power, especially with an undervolt. So again, imo you should be fine, but i havent tinkered with many molex adapters ever so, take my opinion with a pinch of salt
