Looking for a 3rd (going to be) Primary monitor for gaming
I use 2 LCD monitors i've set to 144hz and just use an cheap EIZO Monitor as my 3rd.
I use the 2 Good monitors in the middle and on the left [wich is where i look most of the time] and the cheaper one on the right as an "if i need it i have it" or just to quickly check something/look at something.
Reference image:
As a 3rd monitor, you don't need a high end QLED or an OLED with nuts blacks and colors if you barely look at it or don't do anything you'll need any of that for.
What type of 3rd monitor you need is FULLY depending on what you wanna do with it.
Do you want all monitors to be the same, can it be a different size, does it need to be a high refresh rate or highly color accurate?
But for the norm, just buy a monitor that you think looks good and inform you self about it and if it fits your needs,
I hope that helped ^^
