What PSU do I need for my build?
Solved by Shadow Gamer,
Go ahead and get a Corsair CX 750M... http://www.amazon.com/dp/B00ALK3KEM/?tag=pcpapi-20
It should be sufficient.
If you're not so sure, enter the parts into PCPartPicker and add 20 to the wattage it says it will output, and either upgrade or downgrade the PSU to your needs.
Featured Topics
AngelaHornung ·
Posted in General Discussion0 -
StrxmyDev ·
Posted in General Discussion1 -
BaidDSB ·
Posted in General Discussion2 -
AngelaHornung ·
Posted in Linux, macOS and Everything Not-Windows1 -
KeradSnake ·
Posted in Tech News2 -
YoungBlade ·
Posted in Storage Devices3 -
