Hello!
I have an old HP Proliant server that I got after an internship (the closest US thing I could think of) and I found an old server and they told me I could take it home.
Now to the issue. Because it's so old I can't find documentation on how to hard reset the drive slots. Every slot is occupied but only 2 show up in BIOS and Windows 10. When I take them out they are warm so they spin but can't get past that point. What can I do?
Best regards
Zamplex
https://linustechtips.com/topic/1564624-help-with-hp-proliant/
Just now, Needfuldoer said:
If you have a RAID card, those drives might not be part of a virtual drive.
They don't show up under Disk Management in Windows?
No idea if it has a RAID card. I tried to check raid in bios but to no avail.
Nope, only 2 drives show up in Windows. There are 8 in total slotted (I think might be 6).
https://linustechtips.com/topic/1564624-help-with-hp-proliant/#findComment-16366084
Just now, manikyath said:
all the proliants i've dealt with have the slots piped trough a raid controller on the motherboard. depending on the age i should also note they may have disk size limits.
Is there a way to reset the raid config through BIOS? The disks are not large. The biggest is 500Gb (give or take).
https://linustechtips.com/topic/1564624-help-with-hp-proliant/#findComment-16366091
Resetting the CMOS should do that.
https://linustechtips.com/topic/1564624-help-with-hp-proliant/#findComment-16366093
It's not in the actual BIOS setup, but most RAID cards have their own setup utility you can access before the OS boots. Watch the POST screen for a hotkey to mash that brings you to a one-time boot menu, or watch the "Option ROM" messages for a key combination you can press to invoke it.
I don't remember if that's something you can configure through iLO.
https://linustechtips.com/topic/1564624-help-with-hp-proliant/#findComment-16366097
no, it's not in cmos, becasue it's not in bios, it's a physical RAID card module that's inserted in a HP special sauce slot.
i havent touched an old proliant in years, but at post there's a WHOLE BUNCH of buttons it prompts you can press at different times during the process, and one of them leads you to the raid card.
https://linustechtips.com/topic/1564624-help-with-hp-proliant/#findComment-16366099
I got up to a weird screen during boot. Think I found where raid should be but only 2 drives. Is there any other issue?
https://linustechtips.com/topic/1564624-help-with-hp-proliant/#findComment-16366103
Can I reset the Raid card? BUt i think I found it earlier but only 2 disks showed up.
https://linustechtips.com/topic/1564624-help-with-hp-proliant/#findComment-16366104
i mean.. it could be broken, there could be cables missing, the disks might not be plugged in all the way, .. this is kind of like asking someone on the other end of the planet where you could have left your keys.
https://linustechtips.com/topic/1564624-help-with-hp-proliant/#findComment-16366105
yea good point. Just seems weird that slots 1 and 3 work but no other.
https://linustechtips.com/topic/1564624-help-with-hp-proliant/#findComment-16366109
