Low CPU-GPU utilizaiton, Low FPS
16 minutes ago, garlixbread said:
The video above shows a benchmark with a core I7 3770K and DDR3 1600 mhz ram (I'm aware ram speed matters more in ryzen CPUs, but not sure if it should make that big of a difference), same area inside the town I get 40 fps with same settings. Tried it with 2x8 xmp enabled at 2666, 6-7 fps difference
but you don't have i7 3770K
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
current PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
17 minutes ago, garlixbread said:
The video above shows a benchmark with a core I7 3770K and DDR3 1600 mhz ram (I'm aware ram speed matters more in ryzen CPUs, but not sure if it should make that big of a difference), same area inside the town I get 40 fps with same settings. Tried it with 2x8 xmp enabled at 2666, 6-7 fps difference.
Ok, but that's different architecture, even if the 3770K is older the 2400G isn't that better in single thread, the Intel manages RAM better and even has more cache.
Also DDR3 1600 has tighter timings than DDR4 2100 and may be faster overall...
Really the solution is to upgrade CPU and RAM, that's all, slap a 5600 and 3200 RAM ($150) and your FPS will double
System : AMD R9  7950X3D CPU/ Asus ROG STRIX X670E-E board/ 2x32GB G-Skill Trident Z Neo 6000CL30 RAM ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Thermalright Peerless Assassin 120 cooler (with 2xArctic P12 Max fans) /  2TB WD SN850 NVme + 2TB Crucial T500  NVme  + 4TB Toshiba X300 HDD / Corsair RM850x PSU
Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Very well, thanks for the help
