Is it worth spending £30 more for a 3090 over 3080TI
Ed.Nev
I will only be using the 3090 for gaming (and vr), not as a workstation card.
I know its performance is only slightly above a 3080ti, but considering the higher vram capacity and future reselling value, £30 more for a 3090 seems very reasonable.
But is it even worth it to me?
Cpu = 12600k
Psu = Txm 750
Just now, 8tg said:
Yes absolutely, it’s a substantial jump and the vram difference is huge.
Do you think in the next few years i’ll find a use for that much vram in gaming (i’m at 1440p) or will it just be a nice to have.
In Vr it will really help if i have mods but that’s about it
Its less of, will you make use of the 24gb in future, moreso, will 12gb be limiting in future, and thats a decent possibility, id take the 3090, extra performance but also the comfort of knowing you wont be VRAM limited for a while to come
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Especially for less than a 10% price permium.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Isn't a 3090 more expensive than a 4000 series with equal performance?
Also more power hungry...
For those seeking performance on par with the RTX 3090, the RTX 4070 SUPER is an excellent choice. It not only outperforms the RTX 3090 but also comes at a significantly lower price and with reduced power consumption. Additionally, it offers access to the exclusive technologies of the 4000 series. The RTX 4070 SUPER also rivals, and in some cases surpasses, the RTX 3090TI in certain games, all while using approximately 200 watts less power.
Id go 3090 for sure. I had no reason not to. Especially with such a small price difference.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
I'm assuming the 3090 is like $300 or less.  Hope he's not paying 4070 super money for it.
OnePlus:
Other Tech:
Cpu = 12600k
Psu = Txm 750
Are you buying these GPUs new or on the second hand market? Also, at what price?
