Put it in a cupboard / closet? If its already in the case but you just arent done yet just close the panels and go to bed.
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
2 minutes ago, MiszS said:
I would just put it in the case box, since its usually pretty strong, and will obviously fit
Its not in the case yet
Then just put it in the closet like the other guy said, or somewhere safe, I don't know how your home looks, so can't tell you where exactly
Could i just keep the mobo on the table and then cover it with a cardboard box?
Yes listen to this guy. put everything you can back to their box or put it in the case box. The case it self, as long as you close the side panels should be safe from any evil pets around. Again should and not would.
But if you listen to my advice and if it were me, I won't even sleep until that's built and boots. lol
