CPU temps with watercooler
Solved by JDB,
On 3/20/2024 at 12:08 PM, Blasty Blosty said:Remove the old paste with a cloth (microfiber or cloth, not paper as it can leave residue), and add another layer. A pea sized amount will do.
I've noticed that I installed it incorrectly. I used the AIO on the front of the case instead of the top, so it should be intake, not exhaust as it was before. I'm testing to see if the temps go down.
UPDATE: way better!
