Need Help Choosing a 1440p Monitor
Solved by TatamiMatt,
42 minutes ago, mikeb123 said:Hello, thanks for your reply! The MQ27 is the same price as the Dell. Should I just get the Dell?
The Dell is better at most things though the M27Q has much better HDR colour gamut, so the decision is up to you, id say if theyre the same price the Dell is the better option but if you like really vivid colours the M27Q might be the better option
