USB A female to female adapter in combination with USB C to USB A cable doesn't work
Go to solution Solved by Needfuldoer,
1 minute ago, komna said:
I also tried with this (more convenient) cable:
If I had to guess, both of those cables are probably only designed to connect a USB C device to a USB A port, not the other way around.
At least on Android devices back in the day I remember you needed an adapter cable that was wired to tell the phone "you're the host, not the device".
You probably need a cable that specifically has a USB A female connector permanently attached to it in order to connect a USB A device to a USB C port.
As described in photo. I have that specific USB adapter which I checked previously and it works in other configurations, but when I try to join it with USB C to A cable nothing happens (both on PC and Android phones). I don't know why. I tried with multiple cables, with multiple sticks, and other peripherals but nothing works.
Also good chance that cable is only charging no data
7 minutes ago, emosun said:
why are you using the female to female adapter
Just because I have it. It was used before for printer which was very far from PC. I have 2 of these and they still work with printers so they are not broken.
No. I tried with multiple cables, and all cables works when I connect them for example between PC and Android phone.
yes but why not plug the drive directly into the the usb C to A cable
Of course, I can do that. This is just something that bothers me from my curiosity because I don't see obvious reason why it won't work. There must be some technical issue. Sorry, maybe I just have to much free time so I'm making up problems where is no need. 🙂
Does that C to A cable have conductor pads on both sides?
USB A to A cables and connectors shouldn't exist, but unfortunately they do anyway.
