Power supply buzzing. Problem or not?
Go to solution Solved by Hinjima,
12 minutes ago, filpo said:
My power supply (NZXT SP-650M from H1) has started buzzing (or at least I’ve started noticing it just now). It’s mostly occurring when I stress test the gpu or cpu or both (like games, furmark and prime95) and it just quite weird. Might’ve been happening before but I didn’t notice. There was buzzing before just loading up windows but it’s mostly gone away now (from booting into windows) however it’s not loud enough to hear it when all the panels and fans are on
Any ideas?
Could be coilwhine?
My RM750i has a little of it. Only noticeable if I put my ear next to my PSU though.
Any ideas?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1561978-power-supply-buzzing-problem-or-not/
Any ideas?
Could be coilwhine?
4 minutes ago, Hinjima said:
Could be coilwhine?
that's good to hear. Should be fine then if it's just coil whine. Just wasn't sure. Thanks!
Total: £1040.95
Absolutely!  If you can't hear it with the panels fans on I would guess its coilwhine 🙂
My RM750i sound similar to this.
mine is more like a literal bzz, though it is an NZXT unit so that might be a difference
a bit like this
Total: £1040.95
a bit like this
That is disugstingly loud and probably more than just coilwhine.
Coilwhine can sound very different to eachother like a bzz or high pitched REEE.
You said you can't hear it with sidepanels on so I would say that its just normal coilwhine 🙂  I wouldn't worry.
a bit like this
Potentially stupid question here...you rule out that it's not the fan that's making the 'buzzing' noise?
It’s definitely not the fan, unplugged all except the CPU one and buzzing originates from there
Thanks!
Total: £1040.95
Thanks!
I'm talking about the power supply fan.
it wasn't spinning at all during a load or on idle
Total: £1040.95
