Ryzen 5 5500
RX 6600
16GB DDR4 RAM
550W PSU
Hey, just need a recommendation about the new build that I'm planning to build. With the CPU and GPU will it run smoothly for about 3-4 years. I probably not upgrading my PC for 3-4 years. For the motherboard, I was thinking about asrock B550M Pro SE
https://linustechtips.com/topic/1561950-solid-pc-for-2024/
The Ryzen 5 5600 has a decent performance increase over the 5500 so I recommend it if you can afford the upgrade
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1561950-solid-pc-for-2024/#findComment-16346400
What games? What resolution? What detail settings? And most important, budget and location?
The configuration you posted won't hold up to 1080p high gaming for 3-4 years. 1080p low to medium, probably. The R5 5500 is weak, and if you're se ton AM4, I'd shoot higher if budget allows.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1561950-solid-pc-for-2024/#findComment-16346401
15 minutes ago, Kidd_Katz said:
Ryzen 5 5500
RX 6600
16GB DDR4 RAM
550W PSU
Already low tier now, won't last that long, try to get a 5600 or even better a 5700X3D, and at least a 6600XT, this would make a nice 1080p build
https://linustechtips.com/topic/1561950-solid-pc-for-2024/#findComment-16346408
Targeting at 1080 mostly at High setting, but mostly at casual games like Dota and Genshin. Not a lot of AAA games, most likely a games that come after 2019 to 2023 like AC games and other single player games. Saddly my budget doesn't really allow it for the moment but thanks for the info
https://linustechtips.com/topic/1561950-solid-pc-for-2024/#findComment-16346417
Might thinking about the 5600, but is it a big gap for the 5700X3D? And for the GPU, I do think the XT version is better but its little over my budget. Thanks for the info
https://linustechtips.com/topic/1561950-solid-pc-for-2024/#findComment-16346421
Yes there's quite a gap, non only 5700x3D has 8 cores to 6 on the 5600, but the cache thing really helps in game and it gets performance similar to way faster chips like a 14600K
https://linustechtips.com/topic/1561950-solid-pc-for-2024/#findComment-16346430
Need to see budget + location otherwise you'll keep getting recommendations that are out of reach.
R5 5600 is the obvious step up (double the cache) and also which DDR are you getting 3600MT/sec and CL16 at least?
Main rig: Ryzen 7 7800X3D, RTX3080Ti FE, 32Gb Teamgroup Create-T DDR5-6000C30, AC Freezer3 280mm AIO, Asrock Steel Legend X670E, M.2 2Tb Samsung 990 Pro, M.2 1Tb WDSN550, SATA 8Tb WD80EFAX, Corsair HX850, LianLi O11 Air Mini + 3x NF-A14's, MSI MPG 271QRX (27"/1440P/360Hz), Gigabyte M27Q (27"/1440P/170Hz), Asus PA248 (24"/1200P/60Hz), G815 kbd, G Pro X Superlight 2, Audezee Maxwell.
Games room "TV rig": 5800X3D, AC Freezer2 280mm AIO, ASUS Prime B450M, RTX4080S w/iChill AIO, 32Gb TridentZ DDR4-3600C14, M.2 500Gb & 1Tb WDSN550, 8Tb WD80EFAX, BeQuiet Straight 1000W,  LianLi O11 Air Mini, LG G4 (55"/4K/120Hz), G815 kbd, G502 mouse, LG G1 Soundbar / Audezee Maxwell.
Lounge HTPC: Minisforum UM760 Slim, Ryzen 5 7640HS, 16Gb DDR5, 1Tb M.2, LG C2 (42"/4K/120Hz), Logitech Touch K400.
Laptop: LOQ16, RTX4060, 16Gb DDR5, 2x 2Tb SN990 M.2.
NAS: Synology 1812+, 3Gb RAM, 3x16Tb Seagate EXOS RAID5, 1Tb MX500 cache, 3x3Tb WDRED RAID6, 120Gb SSD cache.
https://linustechtips.com/topic/1561950-solid-pc-for-2024/#findComment-16346688
