driver.... big problem....
Go to solution Solved by Levent,
i use slimdrivers and it works + it is free
does anyone knows if there is a software that shows you the driver you need? i'm serching 2 days and i cant find anything...
Yeah, its actually pretty simple.  Just look at the component you want a driver for, and search it up :D If you want chipset, sata drivers they are found on the motherboard's manufacterer's support page.  If you want graphics card drivers they are found on the graphics card  manufacterers support page.  I wouldn't recommend it but you can also just install all your drivers from the disks.  Pretty easy.
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2080931
but my friend.... if i dont really know which drivers need an update? how can i find it out?
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2080946
because you just go to device manager, find the hardware driver you want to update and find out the driver version.  Then go to the driver website and see if there is a later driver.
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2080952
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2080954
and thats what i'm gonna do in every thing i dont know if it needs an upgrade?
in 1231244325837245623 years i will be finished
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2080956
actually its pretty quick, and is the safest path.  If you use software to update your driver automatically EG:DriverBooster it can cause lots of issues such as corrupt drivers, incorrect installation and for a chipset driver or sata driver that can cause blue screens galore and instability like crazy.  I know because I did it with a sata driver, reinstall after reinstall.  Finally.
I recommend doing it manually or just updating all your drivers.
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2080966
that is the right answer!
slimware is partnered with AVG I think, I work for AVG.  I hate that program's guts allot of people also think its malicious.  I dont recommend using it but oh well.  I'm here if you ever run into trouble :)
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2080967
go on the start menu and type in Device Manager and double press on the a section you want to update and then the product name should come up,on the product name press left on the mouse button and Properties and then on the select the Details tab. Once you have selected that press on the drop down menu select Hardware IDs and copy the first number into Google and it should tell u what version it is and then go to the manufacture website and check what latest version there is available to download and then lastly go back to the device manager and select driver tab and see what driver you have got installed. If its not the latest one as the manufactures website says, download and install that driver.
        My PC Specs:          CPU: i5 4690k(stock speed of 3.50GHz)          GPU: MSI GTX 770 4GB          Storage: WD Blue 1TB HDD and 120GB Samsung 840 EVO SSD             Ram: 8GB Corsair Vengeance Pro 1600MHz           Motherboard: Z97 Asus Maximus VII Ranger          PSU: Corsair RM650 650W          CPU Cooler: Coolermaster Hyper 212 EVO                    Case: Fractal Design R4 Black Pearl with window         OS: Windows 10 Pro
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2081037
i tried slimdrivers.... works fine :)
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2081058
oh ok. Well i would have recommended it doing it manually cause Slimdriver may cause some issus
https://linustechtips.com/topic/156106-driver-big-problem/#findComment-2081090
