need help with some ram
Go to solution Solved by Somerandomtechyboi,
12 minutes ago, filpo said:
Just get whichever is cheaper
get whatevers the cheapest 6000c30/32 kit and be done with it, if 6400c32 is for some reason cheaper than 6000c30/32 then after enabling xmp youll want to manually set ram feequency to 6000 so its basically just 6000c32 with guaranteed 10000+ capable hynix a dies
as for brand preferences teamgroup (apparently has a tendancy to use hynix a die) and especially klevv (literally hynixes consumer divison) but this isnt worth spending over 5€ for and this is completely irrelevant for 6200 and up which are guaranteed hynix a die aside from that one corsair 6600 bin with microns but that one should be easy enough to avoid, also avoid crucial/micron cause microns are pretty crap on ddr5
https://linustechtips.com/topic/1559827-need-help-with-some-ram/
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Tx for the help
