https://linustechtips.com/topic/155979-building-pc-help/#findComment-2079049
we need a budget location and uses before we can help you...
Specs
https://linustechtips.com/topic/155979-building-pc-help/#findComment-2079051
i had an amd athlon x4 left over from a project along with a radeon hd7770 and wanted to build new system including these parts
if you guys (and girls) would be kind enough to leave a pcpartpicker link if you want to suggest any builds that would be great
which X4?
Linus once unboxed a Toblerone
https://linustechtips.com/topic/155979-building-pc-help/#findComment-2079052
