Hey everyone,
I'm really desperate for help.
For months I'm trying to update my BIOS on my Aorus B650 Pro AX, to see if post timings will improve.
My BIOS is from 2022....
Tonight I made everything worse. I made bootable USB, went into BIOS Q-FLASH end started the process. After reset, it didn't do the job.
Now I'm stuck with endless loop of restarts, I can access BIOS with message "BIOS has been reset. Please re-config your BIOS setup items if needed" every time I access the BIOS no matter what I do.
I attempted even a Q-Flash button in the back of the PC with USB stick but all it does it powers up for loke 2 seconds and then it shuts down....
I have no idea what to do at this point....
Any assistance would be much appreciated!
https://linustechtips.com/topic/1559724-b650-endless-problems/
To use the flash bios button the board, the USB drive needs to be prepared very specifically and you cannot miss a step. Involves the correct file system, an empty drive but the bios file itself and most importantly, the file to be renamed correctly. Its a pretty simple process but most people screw up in the prep.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330496
Did you follow instructions of the PDF file that comes with the BIOS download?
Desktop benching:
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330497
Just now, NargilaGorilla said:
To be honest I haven't. I didn't notice it, I followed YouTube tips and that is probably how I messed it up....
The above videos make all the steps in the PDF excruciatingly clear.
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330509
1 hour ago, NargilaGorilla said:
Do I need to remove CPU and GPU?
To use bios flashback? no
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330568
5 minutes ago, NargilaGorilla said:
Update: I managed to update BIOS, however....I still get message "Bios has been reset...."
And now there is no Aorus watermark when I start it. And yes still endles cycle of restarts....
any debug lights? try reseating your cpu. Also go back on any oc's/under volts you've done if any
Total: £1040.95
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330599
31 minutes ago, NargilaGorilla said:
Look I'm not that good with this so I cant rell you exactly. But no OCs or UV for sure 😔
like on the motherboard, are there any lights lighting up? single LEDs?
something like this
Total: £1040.95
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330643
something like this
Yes there is 3 or 4 of them jumping from one to another... man I just want to say thank you for taking your time to assist me, I really appreciate it!
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330664
No problems. Which lights are they? They should have labels next to them. CPU, VGA, RAM and BOOT
what colour are the lights?
also is it fixed?
Total: £1040.95
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330672
also is it fixed?
Im not in the house at the moment, I'll update you as soon as I can!
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330693
can you check your manual to see what lights those are? I'd say do a CPU and ram reseat. Also set the ram speed to it's highest speed automatically and check all the power connectors are put in correctly
Total: £1040.95
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330741
CPU, RAM, BOOT and VGA all illuminate in the same sequence. One more thing, I just did one more Q-Flash just because on last one after blinking light went off, PC didn't turn off, so I run it again. And same thing, blinking light is off but PC is still running, its supposed to shut down on its own....
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330757
RMA your board.
I have it, and updating bios is simple and easy.  Anything making it otherwise is a defect.
I've updated it for each new iteration and it's stupid easy.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1559724-b650-endless-problems/#findComment-16330911
