Match for 7600x?
Go to solution Solved by PowerPCFan,
6 minutes ago, Fankywanky said:
What gpu is a good match for the ryzen 5 7600x that costs 650$ and under?
I feel like a 4070 super or 7800xt is a good fit. Don't want to go too overkill but the 7600x can handle most GPUs (excluding 7900xtx and 4090, you'll want a ryzen 7 or higher for those)
hi
https://linustechtips.com/topic/1558928-match-for-7600x/#findComment-16325237
