29 minutes ago, kriksis said:
My budget is 1350$ Made this build for 1440p 180fps gaming, all black aesthetic. Make sure to leave a comment below😊
https://pcpartpicker.com/list/GjkBWt
looks good, how come the prices are so low if I may ask?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16322996
Considering the prices are set and not exactly cutting-edge components, second-hand seems likely.
I've gotten to know some stuff, but am far from omniscient, so don't take my advice as gospel and wait for other opinions - I just like throwing in my two cents when I can.
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323020
7700x is 60$ away from 7800x3D it is quite the cutting edge
current PC:
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323035
the prices are pretty low in my country, but the CPU is cheaper than normal because i get the tray version (doesn't come with the original box but it cuts down the price by a lot)
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323377
oh the tray version, I got my 5600 as trey version too, the price cut was quite good despite needing to buy a cooler, but I was fine with that
what country?
current PC:
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323382
30 minutes ago, kriksis said:
I'm from Latvia
what do you plan on doing on your new PC?
current PC:
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323417
42 minutes ago, kriksis said:
I'm from Latvia
I just posted a Latvian build on another tech site.  I see the Latvians have this cpu and we still don't have them here in the USA. We have to order them from a Chinese website =/
https://1clix.eu/amd+ryzen+5+7500f.gs
https://www.dateks.lv/en/meklet?q=amd ryzen 5 7500f
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323427
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323430
16 minutes ago, kriksis said:
just gaming really but in the future i might start making videos
could get cheaper case, maybe, idk how case prices go
current PC:
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323529
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323534
Consider Corsair RM850e PSU if it's cheaper
current PC:
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323548
is it better than the EVGA??
little bit, but if it's more expensive then it's not worth to pay more
current PC:
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323628
14 minutes ago, kriksis said:
its 4 bucks more, should i change it
it's fine, it's like a difference between a Lambo and a Bugatti basically, the Corsair RMe is A tier and the Supernova is B tier on a PSU tierlist
A tier is like almost everything basically tested on protections and more technical stuff
B tier is like one or two things less tested but still many important and slightly less important things tested
current PC:
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323646
Just now, podkall said:
it's fine, it's like a difference between a Lambo and a Bugatti basically, the Corsair is A tier and the Supernova is B tier on a PSU tierlist
thanks for the explanation, ive also changed a few components for looks but they still cost the same, what do you think? i read a couple reviews saying the the motherboard has slow boot times would that be a problem?
https://pcpartpicker.com/list/BDDYqR
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323651
ummm, I don't really know how motherboard could affect boot times, or if it even matters, it's just a boot time it's gonna be less than 10 seconds guaranteed if you have an SSD,
and as I expected, it's just DDR5 thing, there's quite literally no way to prevent first-time long boots:
The motherboard is good, there's probably other motherboards within same price that are almost exactly same spec with maybe one less M.2 heatsink, because I think the Tomahawk has 2 heatsinks
but you know... it will really depend if saving 30-40ish $ will even open up budget for something else,
if there even is something else worth getting (like 2TB SSD or somth since we're scraping the budget's ceiling)
current PC:
https://linustechtips.com/topic/1558554-first-ever-build/#findComment-16323680
